Results 1 to 10 of 17
Thread: Maytag Water Dispenser Issue, vibrating
    Mar 2009
    Florida
    Default Maytag Water Dispenser Issue, vibrating
    Model Number: MSD2650HEQ
    Brand: Maytag
    Hello! First post here.
    I have a Maytag MSD2650HEQ side by side
    When I try to dispense water from the door, a loud vibrating noise comes from the behind the fridge, near the top. Water flows fast initially, then trickles.
    I have tried 2 brand new filters with no change. I have checked water pressure from the wall and it is like a fire hose. I also removed the hose coming out of the valve (the one that leads to the tank) and it still does it at that location.
    It seems like something is causing it in the filter area, but I cant get that assembly apart.
    Any ideas? Thanks in advance!
    Your water inlet valve in the back of your refrigerator where your water supply line hooks up to is possibly bad.
    Mar 2009
    Florida
    I just tried by-passing that valve. I had water on from the wall, going through the filter, then exiting hose that normally goes to the valve in a bucket. That set up made the same noise. So maybe its not the valve?
    Thanks for your help on this. I know its not an easy one.
    Repair-man in this forum said it was the filter-head will need to be replaced:
    Water Filter Housing 67004106 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Mar 2009
    Florida
    Thanks a ton for the help.
    Glad to help.
    Mar 2011
    cincinanti
    Default Maytag filter head
    Hey Jake,
    I'm having the same problem with my fridge. Would the same filter head part number apply for Maytag model MSD2655HEW?
    Yes, your model uses the exact same one.
    Mar 2011
    cincinanti
    Thanks a lot Jake. I'm pretty handy at putting things together/replacing things. The directions appear to be very straight forward. Is this something someone typically can get done by themselves or would you recommend calling in someone?
    What I usually say is if your mechanically inclined and have fixed other things around your house, then you should be able to do it.
  1. Replies: 3
    Last Post: January 26th, 2015, 10:17 PM
  2. FIXED: Maytag side by side water dispenser issue
    By srb104 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 10th, 2014, 03:57 PM
  3. Maytag refrigerator water dispenser vibrating
    By khf531 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 18th, 2013, 04:03 PM
  4. FIXED: Vibrating sound from water dispenser when filter is changed
    By dmeek51 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 23rd, 2012, 12:37 PM
  5. Maytag Side-by-Side Water Dispenser Issue
    By Worjd in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 5th, 2008, 11:01 AM
