Results 1 to 2 of 2
Thread: Whirlpool Duet F11 code within first 30 sec
    Jun 2009
    California
    Default Whirlpool Duet F11 code within first 30 sec
    Model Number: GHW9300PW1
    Model GHW9300PW1.
    F11 code withing first 30 sec.
    Diagnostic fails during C01.
    Replaced CCU, door latch, pressure switch.
    What's next?
    Ok, since you already replaced the CCU, door latch, and pressure swith, only part left is the motor controller board.
    Here's the MCU(Motor Control Board) for your model, yes its located at the bottom left side when you open the bottom access panel:
    Manufacturer part#8182706 is RepairClinic item#1184161
    If you purchase parts from our links here and you install them and it doesn't fix the problem, you have a 365 day full refund.
  1. FIXED: GHW9400PL1 Whirlpool Duet F06 error code
    By 3fordasho in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 29th, 2014, 12:25 PM
  2. F11 code on Whirlpool Duet
    By ericruuska in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 11th, 2013, 10:11 PM
  3. Whirlpool Duet - F/09 code
    By sienask in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 26th, 2012, 05:05 PM
  4. F11 Code on Whirlpool Duet HT
    By gorocketgo in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: July 16th, 2012, 01:47 PM
  5. GHW9200LQ0 Whirlpool duet error code F-H
    By leoramos97035@aol.com in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 20th, 2010, 03:19 PM
Tags for this Thread
