Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: GHW9400PL2 Whirlpool Duet Washer -Getting FH code
    Oct 2009
    Atlanta
    Default GHW9400PL2 Whirlpool Duet Washer -Getting FH code
    Model Number: GHW9400PL2
    I am gettting the FH code on my washer. It seems to happen when it gets to the rinse cycle. We have had this washer for 2+ years with no issues. I have taken off the hot and cold water hoses and blown them out. I also checked the screens to make sure they were clean. I also took the plug out of the water pump and cleaned it out. Checking other threads it looks like it could be the flow indicator or the pressure switch.
    I really do not know how to test these without just replacing them. Looking for help.
    Glenn
    Hi Glenn,
    Since it only happens at the rinse cycle, that should be cold water only, has your cold water pressure decreased? I always take the fill hoses off and get a bucket and run both the hot and cold into the bucket to make sure there's plenty of water pressure coming out of both.
    First run the diagnostics test as shown here on Page 5 here: www.applianceblog.com/manuals/8181790.pdf
    It will automatically check the flowmeter & the cold water inlet valve in C:01
    Oct 2009
    Atlanta
    Thanks for the info. I ran the diagnostics test and it repeatedly codes out 60 seconds into the C:01 test. I took the flowmeter off and blew through it. I don't have a multimeter to test.
    I will check the cold water flow but I don't think that is the issue.
    Glenn
    If you start a cycle with just cold water only, does it fill fine without getting the FH error code?
    Its sounding like the flowmeter is the problem if so.
    Its possibly a bad flowmeter, here's the one for your model:
    Whirlpool WPW10110225 Flowmeter
    Oct 2009
    Atlanta
    I did run it before on a cold cycle and it did okay.
    I will replace the flowmeter and hope for the best.
    Glenn
    Ok, keep us posted Glenn.
    Oct 2009
    Atlanta
    Replaced the Flowmeter and the washer is now working again!
    Thanks Jake
    Glenn
    Excellent Glenn, good job.
    Apr 2014
    Central Illinois
    I have been having the same issue with my washing machine. The cold water barely trickles in. I've ordered the flowmeter as well! Thank you for posting!
    Quote Originally Posted by Paula L. Miller View Post
    Do you have the exact same model number as Glenn?
  1. Error code f01 whirlpool duet washer
    By Heather Eric in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 14th, 2016, 08:55 PM
  2. Whirlpool Duet Washer Error Code F 11
    By JTLee in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: July 22nd, 2015, 09:37 PM
  3. WFW9400SU00 Whirlpool Duet Washer F20 error code
    By joshuamcgee in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: June 4th, 2015, 12:36 PM
  4. Whirlpool GHW9400PL2 FH error code
    By weldit in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: December 19th, 2014, 01:10 PM
  5. F02 code on my Whirlpool Duet He Washer
    By hapkido57 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 4th, 2012, 06:43 PM
