Results 1 to 10 of 10
Thread: Kenmore gas dryer will not stay lit
    May 2010
    WI
    Default Kenmore gas dryer will not stay lit
    Model Number: 110.73022100
    Hi all. Hope you can help me here. I have searched these forums, learned much, but cannot seem to find the same problem I have. Note that this is my first ever foray into gas dryer operation and repair, so I am starting with almost no knowledge (and no operational manual for the dryer).
    Here is what I have figured out. I push the start button on the dryer, the glow coils come on, the gas ignites, the glow coils go off, the gas runs for about 30 seconds to 1 minute and then goes off.
    Any suggestions as to what may be causing the gas to go off so quick or what I should look for.
    Note: dryer model is Kenmore Elite 110.73022100
    Its either 1 of 2 things causing it.
    If the flame is lazy and not strong, it will overheat the hi-limit thermostat and cut off prematurely. So first pull your dryer away from the wall, and take off your exhaust hose from the back of your dryer, then run it with no clothes in it and see if it stays on longer and cycles off and on normally.
    If it still doesn't then your gas coil solenoids are bad.
    Here's the gas coil kit for your model you can order here:
    Gas Valve Solenoid 279834 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Watch this video:
    A lazy flame indicates poor air flow through that burner tube, thus usually a clogged vent or vent exhaust.
    If you pulled the dryer away from the wall and the air flow was strong out the back of your dryer, then the flame shouldn't be lazy, if the gas is still cutting off prematurely or the flame doesn't come back on again, then the gas coils are bad.
    Unplug or turn off the breaker to your dryer before changing the gas coils.
    May 2010
    Orcutt, CA
    Default Similar symptoms but heat stays on longer
    Hi, I have very much the same problem, but a little variation:
    When the dryer is started cold, the coils glow, the gas lights, and a strong flow of warm air comes out the vent. Then after about 8 minutes of drying, the temp out the vent reaches ~155-160 F, and the flame goes out. I can only get it to reignite after resting for a period of time (perhaps 30 minutes after the dryer cools down). Sounds like a sensor? I see all four sensors (2 on the vent, 2 above the burner), but which one?
    Thanks in advance.
    Kenmore 80 series
    model# 110.72812101
    Ser MM0101219
    Its your gas coils thats bad, order them from the link I posted above and change then and you'll be back in business.
    May 2010
    Orcutt, CA
    Jake, you're the man! I swapped out those coils, and I'm good to go. Thanks again! And Repair Clinic was great too.
    It took me a while to figure out how to get to the coils, but eventually I found a schematic online showing the screws next to the lint screen, etc.
    Steve
    Good job Steve.
    Nov 2012
    Cleveland ohio
    Hey guys-
    I am having the same symptoms on the Kenmore 80 series I bought from a friend last week. Lights right up from a cold start, gets hot , shuts down, and then when the ignitor coil goes to re-light it does not re-light or have any flame, then goes cold. Switch to another setting and it will re-light but shut off then not re-light again. Blower blowing. I ordered the gas coils yesterday and will be installing them Saturday. Unfortunately, wife thinks I got ripped off and has no patience- but I have to fix it before I can sell it anyhow. She is on a mission to buy a new one tonight. I will keep you apprised of my progress, so that other folks with the same symptoms may be able to fix theirs...
    Yes the new gas coils should fix yours as well.
    Nov 2012
    Cleveland ohio
    Default Dryer is back in production!!!!!
    Well boys (and girls...?) gas coils did the trick! Put them in last night (a whopping 6 screw ordeal...) and it worked like a good gas dryer should. Unfortunately, too late for this unit as the old lady has a new one being delivered tommorrow. Good news for my neighbor though as they bought this one. Thanks a bunch for the pint in the right direction and good luck in your future fixes!
    Alex
    Good job Alex.
  1. FIXED: 110.68972891 Kenmore Series 90 Plus Dryer Will not stay On
    By jrc0109 in forum Sears Kenmore
    Last Post: January 19th, 2017, 10:22 AM
  2. Kenmore Dryer - Won't Stay On and No Heat
    By gaensey in forum Sears Kenmore
    Last Post: December 23rd, 2013, 07:39 PM
  3. Replies: 1
    Last Post: November 27th, 2011, 08:34 PM
  4. Kenmore Dryer 110.96588210 Won't Stay On
    By flyspec in forum Sears Kenmore
    Last Post: October 17th, 2007, 11:14 AM
  5. kenmore dryer wont stay on
    By sun45 in forum Sears Kenmore
    Last Post: June 26th, 2007, 10:36 AM
