Sean Duffy
- unkown
I have a 1939 frigidaire cold wall and I need some help.
I have used the fridge for many years with no problems. Then about a week ago it just quit with no warning.
I looked at the wiring and it was all in very bad condition. The insulation was simply coming off. I took some "before" pictures and It still had the wiring diagram on the back. using the diagram I rewired it. In this process i found a wire broke off the start capacitor. I replaced the start capacitor. I have the exact same problem as before. I have checked my work again and again.
I got into the relay and if I close the switch with a test lead or screw drive the start relay pulls in for second and the compressor starts. But when I let go of the contact it open and the compressor stops.
I closed the switch indicated by the orange arrow.
Any help is greatly appreciated.
