1950's Frigidaire Refrigerator thermostat
Ksharpe
Florida
This is my first time on this site. I have an old 1950's frigidaire that I have never had any issues with. All of sudden it started freezing everything solid. I turned it off completely and let it defrost. Turned back on and put on lowest setting and it still froze all the drinks. From everything I read it seems to be the thermostat. I'm not sure if that is the problem and if so, there are so many different ones I'm not sure which one to get. The number on the part in my fridge is 0519. Picture below. I would appreciate any help or feedback.
The model number is stamped in black ink on the rear of the refrigerator. Post that model number and I'll look up to see if a replacement thermostat is still available.
Ksharpe
Florida
You may have to zoom in if possible. It's the best picture I could find. The numbers read 5850247 in the first square and then it reads 1607219. I hope this helps!
I’m afraid it doesn’t. As I said the model number is stamped in black ink on the back of the fridge.
Ksharpe said:
AR-60 is a 1952 model.
I'm afraid the thermostat for it is discontinued and is NLA. I couldn't find any still available but you can try searching for any of these part numbers as any of them should work for your fridge. Most recent # 5309948865 replaces previous #'s 09948865, 9948865, 06580992 and 6580992. Maybe someone's got old stock of one kicking around? They come up occasionally on eBay. One was sold on eBay Nov. 11th and another in Sept. 29th.
BTW. I notice a 3-52 on the pic of the tag you posted. It is very possibly the actual manufacturing date.
Ksharpe
Florida
I read that somewhere but wasn't sure. I am having the hardest time finding a replacement thermostat. I don't know anything about this stuff (as far as mechanically). Is there a replacement part that can be used that is not an original? I just want to get it working again!
Thank you!
Kelly
Are you referring to the date? It jives with the general model date I stated, so is likely accurate.
I told you it is discontinued and no longer available. You can't just buy one unless you can find someone getting rid of old stock or maybe finding a used one. eBay is the most likely place. Keep checking.
There may be an aftermarket 'universal' thermostat by Ranco or other manufacturer that could be used to replace it, I however don't know what it is or I would have said so. Someone, somewhere might have a cross reference to a suitable repacement. I'm afraid I don't know who. Sorry.
