Noggenfogger
My home came with a 1950s-era GE electric range, and it's in remarkably good condition for a 50 year-old appliance. After much research, I discovered that my stove is a E11 "Liberator" (https://inspectapedia.com/Design/GE Appliances-1950.PDF - Page 10).
I have a slight problem that's led me down a rabbit-hole: Only 1/2 of every heating element gets red-hot. For the smaller (6") elements, the middle section is working. For the larger (8") elements, the coils are interwoven, but it's the same thing: only 1/2 of the coil gets red. I find is suspicious that every element has the same problem, so I'm asking for help.
I tried calling GE to get a copy of the owner's manual, but they had a hard time finding this model in their systems, and when they did find it, they couldn't give me a copy because it was on micro-fiche in their office-buildings which are off-limits due to COVID. My troubleshooting so has led me to believe that it's a problem with my switches, but I'm no expert here. Here's what I've tried so far.
Are the heating elements supposed to get fully red-hot when on the highest setting? Is it likely that my switches are broken / corroded? How should I go about fixing them?
Thanks for your help.
- I replaced one element with a new (GE-branded) electric element. That did not fix the problem.
- I checked the wall-socket with my multimeter. It is providing 240V.
- I disassembled the head unit, and checked continuity and voltage going to each switch: it seems to be fine.
- Three wires go to each switch, I measured 120V from the first wire to the middle wire, and 240V from the first wire to the third wire. I measured 120V from the middle wire to the third wire.
- I used contact cleaner inside one switch assembly to remove any corrosion, then sprayed in silicone lubricant to make the button-action easier.
- Upon reassembly; that burner now doesn't heat on "High", only on "Med"
- I would appreciate some help understanding how these switch units are supposed to operate. Any hope of repairing them? I found the patent for these switches (https://patentimages.storage.googleapis.com/63/0a/83/c9a2b88ade1d3c/US2431904.pdf)
