rico tubbs
- RCA
Been working on our 1950's RCA Estate Range/oven. The oven fluctuates in temperature - set it at 350 and it will vary from 250 to 450. Removed the thermostat and took the Thermocouple out of the oven box. The Thermostat appears to be working okay, when I put a multimeter on it. The thermocouple has some corrosion on it. My questions are:
1) can you clean the thermocouple?
2) how do you test the thermocouple short of hooking it up - is there a way? All of the instructions on line seem to require the thermocouple removed from the thermostat, and that does not seem to be possible when you look inside the thermostat.
3) Can I adapt a modern thermostat/thermocouple to this stove, and if so, what would I look for?
Any insights into this problem would be most welcome.
Rick
Rick
