Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Broken hinge pin holder on Kenmore Dispenser chute
    Jul 2010
    Texas
    Default Broken hinge pin holder on Kenmore Dispenser chute
    Model Number: 106.58706800
    The in door dispenser ice chute flap/cover is broken. Actually, after disassembly, it is really one of the hinge pin holder tabs that is broken. These "tabs" appear to be part of the dispenser holder housing which appears to be non-orderable.
    Any ideas or suggestions other than ordering the whole door?
    Thanks in advance!
    Keith
    Yes Keith, there is a kit to fix this problem instead of ordering the whole freezer door.
    Here's the kit you can order(comes with instructions and VIDEO):
    8201756 Broken Tab Ice Door Kit
    Jul 2010
    Texas
    Default Confirm this kit fixes the tabs on the freezer DOOR
    Jake, thank you. Can you confirm this kit somehow fixes the broken tab on the FREEZER door itself? instead of the tabs on the ice chute door itself?
    Keith
    I really can't confirm that, I've never needed to replace one of these kits myself, hopefully another tech. or member can confirm it. I've referenced this part to many members here and non has given any feedback on the contrary.
    Sep 2010
    Memphis, TN
    Default Repair kit to fix the plastic hinge
    Jul 2010
    Texas
    Default Kit fixed the broken hinge pin and tab
    To closeout the thread I was in, the repair Kit I purchased from RepairClinic that Jake recommended worked great. It took me less than an hour from start to finish. No special tools were required.
    Thanks Repair Clinic and thanks Jake!
    Excellent Keith, I think your the only person here to confirm that the Kit I've been telling everyone to get has worked.
    Fantastic, thank you very much for the update.
    The Whirlpool part#8201756 is the genuine Whirlpool part for this kit, I always advise members to purchase here from the links we post to it directly, as its guaranteed to work or your money back.
    Jul 2010
    Lewisville, Tx
    Can anyone describe the symptoms that lead to the discovery of the broken hingepin or tab? Assuming my unit has the same problem, will this part also apply to model 106.56922600? Also, anyone know the startup and running wattage for model 106.56922600 ? Thanx in advance.
    You can search our threads about others that had this issue:
    8201756 - Google Search
    And yes that kit will work on your model.
    I don't know the wattage your refrigerator uses on start-up or running.
  1. FIXED: Kenmore Coldspot 106.57032601 - Ice dispenser hinge broken
    By hemp in forum Sears Kenmore
    Last Post: September 14th, 2015, 12:33 PM
  2. Ice builing up on dispenser chute
    By blackcat30 in forum Sears Kenmore
    Last Post: October 24th, 2011, 04:41 PM
  3. Ice Dispenser flapper door - broken plastic hinge
    By Texas_Ray in forum KitchenAid
    Last Post: August 3rd, 2011, 03:51 PM
  4. Ice chute broken housing tab
    By MSD2542VEW00 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 3rd, 2011, 12:14 PM
  5. FL FWT445GES0 Broken Spring Holder on tub
    By Bedly in forum Frigidaire/Electrolux
    Last Post: March 30th, 2007, 11:27 PM
