Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Kenmore Coldspot Fridge & Freezer NOT COOLING
    Jul 2010
    Buffalo, NY
    Default Kenmore Coldspot Fridge & Freezer NOT COOLING
    Model Number: 106.79202990
    My fridge & freezer stopped cooling about 2 weeks ago. I have read several posts and this is what I have done so far:
    1. I have taken the freezer back panel apart and the fan was running fine and there was no ice buildup.
    2. I have taken the back panel off at the bottom and cleaned out all the lint. The fan down there was not running until I cleaned everything out.
    3. The condensor is humming when I plug it in. A lot of posts said that it could be the overload and start relay. I replaced both parts and still no cooling.
    Any help is much appreciated!
    You mean the compressor(big black ball) was running? But not cooling at all? If thats the case, then you have either a bad compressor or sealed system freon leak or restriction, either way it will cost big money to have a tech. out to fix it.
    This model was made in 1998, so it would be best to save the repair money for a new refrigerator. Average life of refrigerators now is only 8-12 years.
    Jul 2010
    Buffalo, NY
    Thanks for the quick reply Jake!
    When the fridge is plugged in the compressor sounds like it is humming but its quiet. I replaced the start relay about 3 hours ago and it still is not getting cold.
    Your advice is to just get a new one?
    Yes, if the compressor is running and not getting cold.
    Jul 2010
    Buffalo, NY
    The compressor gets pretty hot.
    No, I meant inside the freezer.
    Jul 2010
    Buffalo, NY
    The freezer is not getting cold and the compressor is hot.
    Right, your compressor is bad, so you can have a tech. come out for $70 and tell you that or you can believe me.
    Jul 2010
    Buffalo, NY
    Thank you very much.I appreciate your help!
    Your welcome.
  1. FIXED: Freezer cold, but Warm fridge side - not cooling? Air flow 101 - HELPFUL INFO!
    By PatrickM in forum Refrigerators & Freezers
    Last Post: November 29th, 2014, 01:30 PM
  2. Replies: 19
    Last Post: December 5th, 2008, 12:50 AM
  3. [FIXED] kenmore coldspot freezer not cooling
    By crzyfish in forum Sears Kenmore
    Last Post: December 2nd, 2008, 12:37 PM
  4. Kenmore Coldspot freezer perfect, fridge warm
    By nandof in forum Sears Kenmore
    Last Post: July 1st, 2007, 10:49 AM
  5. Kenmore (106.56532400) fridge side not cooling, freezer is,
    By OhNoItBroke in forum Sears Kenmore
    Last Post: June 4th, 2007, 12:30 PM
