1973 Frigidaire electric oven range RSE3-36W - infinite heat switch
danw2
Illinois
RSE3-36W
1973 Frigidaire electric oven/range, need top burner infinite heat switch.
I can not find a model number plate or label anywhere along the oven's door frame, back panel, inside the controls panel, or the inside of the wiring junction box cover, so I'm not sure whether the wiring diagram title RSE3-36W is the oven model number or wiring document number. Other data on wiring diagram: Pc. No. 1127697-2-73 FRIGIDAIRE- (EC-910012)
Infinite heat switch has 1973 date code, is a 5 wire unit, for a burner that is rated 2600 watts, is labelled 10.0-11.5A (250V).
Is a replacement available?
