1991 maytag gas stove
Camster
Earth
{91 maytag stove electronic igition}Left front burner sometimes doesnt ignite,will start clicking then a big boom noise flash when it finally does,i had someone look at it but when they did it worked perfect and couldnt find a problem.is it just a bad ignitor or something?
Yes, the igniter is not sparking correctly, or the tiny burner holes that let the gas through are clogged, see if the holes are clogged, if so clean them out and see if that fixes it.
If you could please post the model# that would help to see what type of burner you have, as they make many styles.
