- GDF630PSM3SS
- GE
- 1-5 years
I have 2 years old GE Dishwasher Model GDF630PSM3SS. It started to have blank display not power symptom, similar to tread below.
Sometimes if I do power cycle dishwasher comes back, and then randomly goes off-sometimes while washing sometimes when idle.
www.applianceblog.com
- I believe Control Board is OK - I checked the Bottom-control board, it has Blinking Green. Any other checks I should do ?
- I replaced with GE Dishwasher electric cable and reconnect Ground, Black and white cables. Tested the outlet, it works fine.
- I will order and replace the UI Board on the door. What is my part number?
- On the tread below Jake pointed - WD21X25726
GE WD21X25726 Configured Ui Service Control (AP7033473) - AppliancePartsPros.com
Configured ui service control WD21X25726 / AP7033473 made by GEclick.linksynergy.com
- And if I search by model number I get WD21X25727
GE WD21X25727 Configured Ui Service Control (AP7014265) - AppliancePartsPros.com
Configured ui service control WD21X25727 / AP7014265 made by GEclick.linksynergy.com
GDF630PSM3SS GE Dishwasher Blank display, unplugging resets for one cycle
Hi, I have a GE GDF630PSM3SS that will run one cycle before the display goes blank and is unresponsive. It will work again for one cycle after unplugging it’s power for 10 minutes and plugging it back and sometimes I need to hold the start button and it will make a chirp and start working. I am...
