- ED5GVEXVD02
- Whirlpool
- More than 10 years
Today in the morning found a dump of water on the floor under the freezer door. Opened it up - everything is meting down, more water inside the temperature is around +10, cooler section is around +15 (Celcius)...
Freezer was a bit on a weak side for the last week just cranked freezer regulator a few notches down. Background - the whole fridge started cooling weaker back in July, had to tilt it up and clean the bottom coils from heavy lint/dust clogging. Cleaning completely resolved the problem (no damage was done).
What would be my next steps, check the relay - should it be under large vertical plastic panel in the freezed section? I't not sure how this thing works - one coil in the freezer section distributes cold to regular section as well?
