2012 Bosch SHE55RF5UC/63 Not Draining at end of Cycle
IABeancounter
IA
SHE55RF5UC/63
Bosch
About three weeks ago our Bosch finished the cycle and left the bottom full of water. I scooped out the excess water, cleaned the filters, and ran another cycle - same results.
Since then I have replace the drain pump (no change), cleaned the drain line from the pump, past the check valve, through the dishwasher inlet valve, to the drain. (no change)
I have checked the air gap. (no change)
I checked the dishwater flow sensor to make sure that the little red float does just that. (it does)
There is no water in the lower pan and the flood mode is not activated.
I tried canceling the cycle by using the two button cancel method. - No luck.
I am leaning toward the Control Board in the bottom being the issue (00665512) but somewhat hesitant given the age and the cost of the part.
I can hear the motor running at the end of the cycle and when I shut the door, it just doesn't continue.
Anything I am missing?
jackofalltrades
NY
Not familiar with this model but it sure sounds like a problem with whatever board powers the drain pump. A lot cheaper to fix it than replace it. Buy the part from our sponsor and you can return it if it doesn't solve the problem.
The number I come up with for the lower board is 00706023
