FIXED 2017 KitchenAid Dishwasher KDTE254ESS2 started making some noises and there still some water in the bottom
Bcrazy
KDTE254ESS2
My dishwasher stopped some time during its cycle. Started it again and it started making some noises and then shut off after a few minutes. I checked the filters and found no obstructions, but there still some water in the bottom. Suggestions on what to check next.
Check for a foreign object in the drain pump causing this problem. When you click the drain pump part link below you will see a video of how to remove and replace it.
Drain Pump WPW10531320
Bcrazy
Thanks for the reply Jake, I removed the pump and found a olive pit. I put it all back together and it works fine now.....thanks
Excellent @Bcrazy glad to hear that's all it was.(y)
