FIXED 2017 Whirlpool Refrigertor WRS588FIHZ00 Ice Maker Fail?
artmanr
WRS588FIHZ00
The ice maker stopped making ice. Cleaned out bucket. Filter was recently changed. Checked water supply lines. All good. Unplugged unit. Plugged it in 20 minutes later. Went to bed. Woke up to about 20 ice cubes. Assumed all good. Three days later, no ice. Searched forum. Found similar posts with links to user manual and diagnostic procedure. Took apart the cover to inspect wiring. Nothing looks bad. Don't have meter or skills. Some residual frost/ice in area of ice tray, but nothing blocking or frozen up. More just like frost. Put it back together......
Ran diagnostic tests from front of dispenser unit. Test 47 showed Thermistor good and registering temp below harvest temp. Ice tray is full and has ice. Ran test 44. First digit shows 2 and second starts and 2 and goes to 3. Ends showing 23. Tried to force cycle by pressing SW3 to toggle to 1. Waited. Nothing. I thought it would force a harvest cycle. No such luck.
So I am stuck without skills to test electrical. I did inspect wire harness where it comes out of kick plate on freezer door side. Looks solid and doesn't move at all with door movement. Don't think wiring there is a problem. Did not remove it to see actual wire.
So I unplugged it for 30 minutes and plugged it back in. Registered for this website and wrote this email. Help!! Is it as simple as need a new IM?
Thanks very much!!
Art R
Hi Art,
Remove your bottom kickplate grille, You HAVE TO REMOVE the black wire harness LOOM too, broken wires can be underneath it, look at the attachment below.:)
W10873791 Ice Maker
If you're absolutely sure no wires are frayed or broken, DO PATH 1 below. I'm attaching the ice maker troubleshooting manual below as well.
Service Diagnostics
Functional checks of all components required for proper operation of the IM can be completed through Service Diagnostics. Refer to the Service sheet for the refrigerator for instructions on operating Service Diagnostics.
NOTE: Diagnostic Step 48 – Icemaker – Ice Bucket Detection Switch – Does Not Work
Troubleshooting Paths
Complete the preliminary checks prior to troubleshooting. Then proceed down the appropriate path.
--->Path 1 - If there is ice or water in the ice tray, proceed to Path 1.
--->Path 1 starts on Page 8. 10)
--->If 14VDC is present, replace the Ice Maker.
  • Training Pointer W10869036 - Sankyo Twist Tray Ice Maker.pdf
artmanr
I did take the kick plate off and inspect the wires. Red and green broken. The rest look good. I don’t trust myself to solder anything. How can I repair this?
Take a photo of those broken wires and upload it here, so we can see how much slack you got.
Just order some heat shrink butt connectors and wire wrap. That should do the trick.
You will need this tool:
Wire Splicing Tool 959
Watch this video below:
artmanr
My wires.
artmanr
What kind of solder do I need? The door side wire is pretty short. I’m a bit nervous. Thinking of soldering a splicer wire in between. Any tips?
Do you have any friends or relatives you can ask to help you?
I always add a little extra wire and use just regular wire solder.
Watch this video:
