Islandvic
- GDF620HMJ6ES
- GE
- 1-5 years
First post here on the forum.. looks like @Jake has helped many members on the forum with their dishwasher problems.
Appliance: 2018 GE GDF620HMJ6ES Dishwasher
Problem: No display on control panel, green LED blinks rapidly and continuously on main control board (rectangle style, not the trapezoid shaped board)
History: Probably twice in the past year the dishwasher would not turn on after circuit breaker tripped and was reset. Breaker had to be cycled off/on again for dishwasher to turn on. Now the dishwasher has no display. Previously the dishwasher would turn on when breaker was flipped back on. (older home and one circuit breaker powers the fridge, countertop outlets and dishwasher... so if trips a couple times a year). Dishwasher works perfectly fine otherwise and I prefer to repair it versus buying a new one.
Troubleshooting:
I have checked the following:
- There is 110v to the wiring harness and to the main control board when plugged into the harness
- green LED blinks rapidly and continuously on main control board
- LED continues to blink rapidly when the other wiring harnesses are unplugged
- I have disconnected power to DW rest for over 5-10 min numerous times, with and without the wiring harnesses plugged into the main board. Still nothing on the UI control panel.
- There is 13.5v from control board to the UI board (black/green & yellow/blue wires). I checked at the main control board and at the end of the wiring harness that connects to UI board
- Disconnected wiring harness between main board and UI board and checked continuity with ohm meter at each wire at both ends of harness. Each wire appears to have good continuity between the connectors.
- I can not enter service/diagnostic mode after holding down the Select Cycle and Start buttons.
- The service document that's folded up and tucked under the dishwasher says a steady blinking LED indicates "Software Error, replace MC".
Questions:
- What else can I do to further diagnose the problem?
- Should I replace the main control board, the UI board? I'm leading toward replacing the UI Board, but the the service document indicates the replacement of the main control board.
- If I replace the UI Board, is p/n WD21X31902 the updated part?
- If I can repair the dishwasher, what can I do to help prevent the issue from reoccurring in the future? From my research it appears it's very common for GE dishwashers to have main control board and UI board failures.
I plan on ordering the part today if I can get some help from the forum to confirm which part I need.
For anyone who can offer their experience and expertise in the matter, I appreciate your assistance.
Troubleshooting:
Questions:
