Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: GX2FHDXVY00 Frost on freezer problem
    Jan 2011
    San Diego, CA
    Default GX2FHDXVY00 Frost on freezer problem
    Model Number: GX2FHDXVY00
    Age: Less than 1 year
    Hello,
    We started having a frost problem around the freezer bin door. At first I thought I had left it open, cleaned it and continued on. After a few days, the frost came back and the temperature on the fridge started to go up.
    We disconnected it, left it open and helped defrost it with a hair dryer. There was a lot of ice on the back of the freezer. We left it open for 1 week.
    We turned it on again and it seemed to be running good for about a week and then the frost on the bin door came back. The rubber gasket seems to be good and seal properly. We called a technician and he says that the "cold control" and the "thermistors" are not working and the temperature keeps going down.
    We live in Tijuana (across the border from San Diego) so I'm not really sure what he is referring to. I know the "thermistors" go one in the fridge and the other on the freezer, but is the "cold control" the thermostat or the control where we dial in the temperature?
    Does it sound logical for them to come to this conclusion?
    Last edited by MikelSS; January 31st, 2011 at 09:30 PM. Reason: Copy - pasted from Word and it looked very weird
    Jan 2007
    San Diego CA
    That model has a defrost heater and a defrost thermostat that you should check. The technician you called - did he actually come and check your fridge as a service call, or did he simply say this over the phone?
    Econo Appliance Service - San Diego appliance repair experts!
    Jan 2011
    San Diego, CA
    Thank you for the quick answer.
    The technician came over but he only opened the fridge and the freezer. We exlained all that happened and gave us his diagnostic. I specifficaly asked him about the defroster due to all that I had read before calling him and he said that it wasn't the problem.
    Jan 2011
    San Diego, CA
    Any other recomendation? How do I check to see if it's the defroster?
    Thank you very much!
    Econo Appliance should be able to assist you further in the morning.
    If he doesn't let me know.
    I will need the complete model#, your missing two more numbers at the end of your model#.
    Should be one of these:
    GX2FHDXVY00
    GX2FHDXVY02
    GX2FHDXVY03
    GX2FHDXVY04
    Jan 2011
    San Diego, CA
    Our model is the first one: GX2FHDXVY00
    Thank you Jake.
    Jan 2007
    San Diego CA
    I'm sorry I misread your post the first time I read it. So you have frost forming around the freezer door gasket - it sounds like you have a freezer gasket / door not sealing problem, even if the gasket looks fine.
    Jan 2011
    San Diego, CA
    Quote Originally Posted by Econo Appliance View Post
    That is what I thought also, and when I asked the technician, he told me that it wasn't the problem.
    How can I check it? We've done the dollar bill test and it does come out rather easily.
    Is it my best option right now to buy another gasket and replace it? Do I need any special tools?
    Thank you.
    Just check all around the door gaskets for any leaks, they will be obvious, forget the dollar bill test, just look with your eyes.
    Jan 2011
    San Diego, CA
    Everything seems to close as it should. There are no visible gaps and it also looks square.
  1. Replies: 1
    Last Post: July 12th, 2017, 04:44 PM
  2. FIXED: GSHS6NGBBHSS GE Freezer frost problem
    By Ukbsktbll in forum GE/Hotpoint
    Last Post: February 7th, 2017, 05:07 PM
  3. FIXED: Frigidaire ice dispenser frost problem
    By CERoberts in forum Frigidaire/Electrolux
    Last Post: August 22nd, 2015, 03:01 AM
  4. Replies: 2
    Last Post: August 21st, 2013, 09:09 PM
  5. Maytag MBB2254GEW frost problem
    By marcusH in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 2nd, 2007, 08:04 PM
