Results 1 to 9 of 9
Thread: [FIXED] whirlpool elec range panel buttons not working
    Sep 2010
    Florida
    Default [FIXED] whirlpool elec range panel buttons not working
    Model Number: GY397LXUS0
    Some of the buttons on my Whirlpool range are not functioning. It started with the numbers 3,6,9 stopped working. Then a few days later 0 and 5. I turned off the breaker for several hours and turned it back on and then I got my 9 back working again but nothing else. Now, the Bake button is not working. Several buttons still work - Broil, Self Clean, Cancel, 1,4,7. I have seen some posts where the membrane can be replaced (~$50) rather than the entire touch panel assembly (~$200). Any suggestions on what to try here?
    Thanks.
    Is there any more numbers after the "S" at the end of your model#?
    Yes, you'd just need the membrane.
    The only problem I see in getting the membrane, they list 3 for this model, I'm assuming the difference in the 3 are the colors it is, and I couldn't find which color refers to which part# you need.
    Sep 2010
    Florida
    I'll be home in a few hours and actually check on the unit itself. My order form just shows the GY397LXUS. That is the stainless model. I'm surprised there would be multiple colors for that model specifically. Although, when you look on the website, there are 4 colors total. The touchpads on the stainless and the black model are black, the other 2 are beige or white, so that would be 3 total colors.
    But, the other colors are different model numbers:
    GY397LXUB - Black
    GY397LXUQ - White
    GY397LXUS - Stainless
    GY397LXUT - Biscuit
    Anyway, I'll respond in a few hours with the model and serial from the unit itself. I suppose if the return policy is good, I could always order 1 of the 3, check the color and then return it if it is wrong and order the other color.
    Thanks for the quick response.
    Yes, you have 45 days to return any part for a full refund, less shipping.
    Let us know.
    Sep 2010
    Florida
    Model number is GY397LXUS0. I looked at a couple of online parts stores and some had the color in the description for the membrane, some did not. So, I think I should be able to get the part number for the black one from one of the sites if I need to.
    I'll wait for your response now that I have the correct model number to make sure I am looking for the correct part.
    Thanks.
    Got it, the black membrane, currently $40.54 here:
    Manufacturer's Number: W10207928
    Sep 2010
    Florida
    Default FIXED - Whilrpool GY397LXUS buttons not working
    Everything is working perfectly now. Repair only took about 15 minutes. Very simple and cost me only around $40.
    Thanks a lot!
    Excellent, good job.
    Hi dsherrell,
    There is another member thats replacing this same exact membrane, they having trouble accessing it to change it, if you can explain how you changed yours I'd really appreciate it.
    Their thread is here:
    http://www.applianceblog.com/mainfor...ol-keypad.html
  1. Control Panel buttons not working
    By Borisgoodenough in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 25th, 2011, 02:09 PM
  2. Smoking Control Panel: Whirlpool GBD307PDS09
    By pat_and_leah in forum Whirlpool/Roper/Estate
    Last Post: June 19th, 2010, 11:47 AM
  3. Kenmore over not working, but range is.
    By Team Irish in forum Sears Kenmore
    Last Post: November 14th, 2008, 01:40 PM
  4. Whirlpool range not working
    By Sheri in forum Whirlpool/Roper/Estate
    Last Post: August 16th, 2007, 12:48 PM
  5. Kenmore Elite 110.60052991 Panel Buttons Stop Working
    By Jofelior in forum Sears Kenmore
    Last Post: March 20th, 2006, 03:08 PM
Tags for this Thread
