Results 1 to 4 of 4
Thread: Maytag DE8410 electric dryer - End of cycle buzzer stuck
    Mar 2011
    Texas
    Default Maytag DE8410 electric dryer - End of cycle buzzer stuck
    Model Number: DE8410
    Brand: Maytag
    The cycle completes and the buzzer sounds, but does it not stop until I pull the door open. I think I got it to stop once by rotating the cycle knob to the off position. I checked the push to start button and it does not appear to be stuck in. I set the knob to the middle of a cycle, closed the door, and the dryer does not automatically start, so that furthers my belief that the push to start button is not stuck.
    I cleaned out the entire vent.
    The dryer is NOT plugged in. Is it safe for me to vacuum out all the lint on the inside of the dryer, around the motor, pulleys, et cetera?
    Any ideas on what is wrong?
    al
    Hi al,
    The problem is your timer.
    Here's the timer for your model you can order here:
    Manufacturer's Number: 306040
    Yes you can.
    Mar 2011
    Texas
    Thanks for the response. I cleaned out the interior. There was quite a bit of lint on the motor itself.
    I've run the dryer 3 times since then and each time the buzzer sounded once, and the cycle ended. It is behaving as expected.
    1) If the timer is failing, could the behaviour be intermittent?
    2) The dryer has been squealing since I replaced the heating element about two years ago. Is this due to the cable(s)?
    al
    Yes, then its likely intermittent now.
    Yes, the squeal is likely the cable or something rubbing.
  1. FIXED: Maytag Neptune Dryer stops running and displays HP error code
    By Ryu69 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 30th, 2010, 11:50 AM
  2. Whirlpool Dryer will not start on high heat cycle
    By leith in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: June 27th, 2010, 10:54 PM
  3. Dryer will not shut off after dry cycle
    By Dennis7894 in forum Sears Kenmore
    Last Post: May 24th, 2010, 07:29 PM
  4. Maytag Dryer won't turn
    By Jim_art in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 26th, 2008, 12:48 PM
  5. kenmore electric dryer stops before cycle is complete
    By ragincajundad in forum Sears Kenmore
    Last Post: November 4th, 2005, 06:11 PM
