agdodge4x4
- 253.26762100
- Sears Kenmore
- 6-10 years
This is the freezer:
KENMORE ELITE
253.26762100
The display has been showing 'CE' for a years and usually pushing reset or wiggling cables or opening the door a few times will clear it.
Now it just shows E and it is beeping CONTINUOUSLY. Reset won't fix it. The display is flashing and flipping...I have solved the issue for now by disconnecting and removing the UI and it's board.
I don't see any way to inspect wires or connections other than looking at them from the outside. The wire going into the door by the hinge looks fine and the wire under the freezer appears intact with no damage.
Pushing the UP arrow to 'OFF' quiets everything down and the display does not 'freak out' when it is in that mode. I have disconnected the UI for now as there is no other way to keep it from beeping. However, this makes the freezer run continuously.
What is wrong with it?!?
KENMORE ELITE
253.26762100
