jpcjguy
- 253.9235710
- Sears Kenmore
- More than 10 years
So I have an older Kenmore upright freezer (from 4/93) that recently stopped working (Friday 11/11). The door was left cracked at one point - not sure how long and there was some ice build up at the bottom. I noticed the temps creeping up. So that morning (Friday) I emptied it, unplugged it and left it with the door open. All the ice melted, confirmed the drain was clear.
Plugged it back in on Saturday morning at around 8AM, by 11:30 AM it was negative 9 degrees celsius. I thought "Sweet! working again!" Left it and it got to -16 celsius. Waited until Sunday morning to put some stuff in it - just some ice packs and a couple small things. Then the temperature kept going up until it was room temp. So I unplugged it and let it sit again.
Got home late Tuesday night so yesterday morning I took it all apart and plugged it back in (it was unplugged the last few days). Fan in the back immediately started running, heard some clicks and not much else. Thought that it is done - compressor not kicking on. Then after about 3-5 minutes, the compressor kicks on! ok. .... After a few minutes I see a little evidence of frost on the coils! This was at 7:29AM - and the thermometer I had in there said 15 degrees C. Went inside to get ready and came back at 7:49AM - thermometer says 10 degrees! Progress!
So not sure what is going on. Then I left for work.
I called home at 5:38PM and had my son open it. It is -9°C. So after cooling all day that is what it got to.
Got home at around 7:30PM and it was at -11°C. I then moved the dial from 3 to 6 (max).
Compressor sounds like it is running. It is pretty warm to the touch. But not scalding
This morning at 7AM (Thursday) I went out and it was -4 degrees C. I moved the temp dial back and forth (from warmest to coldest) a couple times and then left it at the coldest setting (6).
Just checked it at 7:55AM and it was -11 degrees C. What the!?!?!? Any advice? I feel like there is freon because it is getting cold - the evaporator appears to be frosting uniformly, the fan is running. The one thing I cannot check is the condenser coils and fan - there is no way to access them - from what I can tell. Could I have a bad temp sensor? I am will to spend a little on it - if it is something small like a electrical part, but obviously not a ton since it is from 1993.
Joe
Joe
