2661532412 Kenmore Stackable Washer and Dryer Combo
Electrovert
Chicagoland
Hello Everybody,
After replacing the transmission assembly, fork assembly (wax motor), and the speed sensor, the washer is working now. The problem I have now is the tub assembly spin violently. This is a bad design. With other model, there is a base that is bolted to the tub assembly. The model I have, only four suspension rods that hold the tub assembly. Replacing the two rear suspension rods will be a challenge since there is no room due to the dryer is mounted on top for the washer via brackets. I tested the washer without any towels and it works okay. Once I put in the towels, the wash will spin violently and bang against the frame. One thing I saw is the fork assw
B. Wax motor will push the fork to engage the transmission
C. If there is voltage, the control board is good
I. Bad wire at fork assembly
II. Bad fork assembly
Here is my step for replacing the suspension rods:
1. Lay the whole assembly on the ground side way.
2. Remove the brackets that hold the washer and dryer together.
3. Move the washer upright
4. Replace all four suspension rods
5. Put everything together in reverse order
Any advise is greatly appreciated.
Thank you.
There shouldn't be a problem. There's enough room to take them out. You only need to remove the front panel and top cover. Easy peasy.
