2nd LG OTR bites the dust
bldn10
Memphis
LMV1683ST
LG
Less than 1 year
I installed one of the above over-the-range units in a house I renovated about 8 mos. ago. We used it during final construction and marketing for several mos. It always worked but the turntable often made a straining sound.
I sold the house about 4 mos ago and 2 weeks ago the owners called saying that the unit was not heating. Everything else seems to work but it does not heat. Rather than mess w/ it, I just bought a new one at Best Buy and installed it 6/20.
Per the owners it worked that day but then on the following Sun. would not fully pop some microwave popcorn. By the time I looked at it, it did not heat at all and the turntable does not rotate. I've checked the voltage at the outlet and it is OK.
What the heck is going on? 2 identical units go out w/i a week. I'm thinking control board rather than magnetron on the new one since the turntable motor is not getting power.
Model#?
Or both....or something else.....making any noises, just counting down?.....these units should have warranty, don't get too deep into it and void your warranty.
bldn10
Memphis
I don't get the logic of this forum's interface - when you start a new post you have to enter the model no., and age of unit - but it does not show in the post. So what's the point?!?
LMV1683ST
Bill/Memphis
Normally it all shows up.
I fixed it up :)
bldn10
Memphis
Operation seems normal except the turntable does not rotate and it does not heat.
Bill/Memphis
Those are definetly two odd things to quit at the same time.
For sure the door switches should be checked as 2 different switches tells the mag and turn table the door is closed it is ok to operate. Failing that, the smart board would then yes be a prime suspect :(
A loose/off wire is common on warranty units, something comes loose in the shipping.
bldn10
Memphis
FWIW the homeowners had the new one fixed under warranty - magnetron. On a brand new unit. not good
At least it had the decency to break while under the warranty! ;)
