3 year-old GE dishwasher GDT695SSJ5SS no lights or power up on control panel
Pilotrace
Eatonton Georgia
GDT695SSJ5SS
3year-old GE dishwasher GDT695SSJ5SS no lights or power up on control panel .Green light in master board/is flashes constant. I have replaced it with a new control board that still flash is constant but still have no power or lights on top control panel. Any ideas on how to fix this problem or what may be causing it. Or do I need to replace the top control panel?
Yes, you have the newer square machine control board underneath the dishwasher, when its flashing it means its working properly.
Then its usually the UI Board that is bad.
To Verify that--->You can check for 13.5 Volts DC between the (black/green) and (black/yellow) wires at the UI Board itself.
Here's the UI(user interface) Board for your model: WD21X23462 Kit Svc Ui Top Logic
Here's another member with this same problem and the new UI Board fixed it:
