30+ year old SXD22S2W Amana Refrigerator finally died........help
kabs996
MA
SXD22S2W
Amana
My Amana side by side that I have had for over 30 years stopped freezing. Model number SXD22S2W My husband wants to fix it because nothing lasts this long. It has never needed a repair in all these years. Do they even make parts anymore? What could the problem be? I hear a fan noise in the back of unit but nothing is cooling/freezing. Its been in the garage for 20 year in extreme hot/cold temps. This thing is a champ we aren't ready to let it go!
Many of them, yes.
There are lots of possibilities. You can read about the most common causes of that symptom at the following link:
LINK > My frost free refrigerator is not cooling properly. What might be the problem?
There is a fan inside as well as at the rear and also the compressor (see the link sabove). All need to function at the same time to produce cooling. Someone needs to check the functioning of them all.
Also is it easy to replace the relay? Which part number is it? Worth trying on our own for now.
Thanks do you think it’s worth fixing? With its age.
It depends on what is found to be the cause.
Usually, yes.
Do you even know if it's a possibility yet?
This link is pertinent to your message. It were supplied by this message author.
LINK > Amana SXD22S2W Compressor Relay
If there is someone that can investigate it to narrow the possible causes, sure.
Dan where is the relay and how do we remove it? Thanks for helping
These are the only things attached to compressor.
will this work as well?
I have no idea. They are not the parts called for on your model. You need more than just parts that look similar.
I never saw your link
Just for my curiosity, how could you miss the link I left?? Please let me know so I can correct how to display related links.
just because I am new and stupid.....ha ha I was more interested in your comment and didn't even pay attention to the link. Sorry BTW My model is the SXD22S2W-P1190416WW. I didnt realize there was more numbers to my specific model...again stupid me.
The relay I linked to is used on all versions of Amana fridge model SXD22S2W. It is for MFG # P1190416WW too.
