Results 1 to 10 of 15
Thread: estate by whirlpool washer model agitates, pumps, but doesn't spin and makes loud clacking noise
    Mar 2012
    tx
    Default estate by whirlpool washer model agitates, pumps, but doesn't spin and makes loud clacking noise
    Model Number: TAWB600EQ1
    Brand: Estate
    hello.
    i have a washer (model above) that will fill, agitate, pump, but when it comes to spinning, it won't spin and makes a loud clacking noise. when it first started doing this, it would spin with the noise, then it would spin intermittently, then it came to where i could open it up and while holding the lid switch, i could rotate the drum by hand and get it started spinning... now it won't spin but still makes the loud clacking noise. i took the cabinet off and the clutch on bottom spins and the agitator spins a little bit (with no clothes inside).... but the drum doesn't spin. the coupler isn't broken. any ideas as to what it is? i was thinking the inner tub drive block but i have no spanner wrench to remove the nut. i thought i'd ask on here to see what others think before i purchase both a spanner wrench and a tub drive block.
    -thanx
    Oct 2004
    Check out the drive block and nut for sure!
    Kitchen Aid washer basket won't budge - Handyman WIRE - Handyman USA
    http://www.applianceaid.com/
    Appliance Repair Aid
    Yeah I've got O.C.D.....Old, Cranky and Dangerous.
    Tip of the day, set your Samsung Smart Fridge to a foreign language so Google can't spy on you!!
    Mar 2012
    tx
    here is a video of what it's doing.
    Oct 2004
    Mar 2012
    tx
    thank you for the replies.... so you think it's the drive block?... i was thinking that too... so if it is the drive block, would i still be able to stop the agitator from spinning easily with my hand like in the video? if i put it into spin mode with the agitator removed, i can still grab the splined end of the rod and stop it easily. i just didn't know if that was possible if only the drive block is stripped. -thanx
    Oct 2004
    Put the washer to a low water level, let the washer fill and the agitation start, then remove power and lower the drain hose to drain out the water....the agitator should be locked into place.
    Mar 2012
    tx
    i did... and the agitator did lock (i couldn't turn the agitator)... so after doing that, you think it is the drive block (when i turned it to spin it still made that noise and the drum didn't turn - like in the video)... thanx!!
    Oct 2004
    Twice I have mentioned that....yes, check the drive block as the best place to start!
    Mar 2012
    tx
    thanx!... i'll order the part and tool now.
    Oct 2004
    Can sometimes get away with a large flat screwdriver and hammer to remove the nut.
    Spanner nut wrench for Whirlpool/Kenmore, General Electric & Maytag inner tub lock nuts
  1. FIXED: Whirlpool thin twin stackable spin cycle makes loud clicking noise
    By xjasonx in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 22nd, 2014, 10:19 PM
  2. Replies: 6
    Last Post: December 6th, 2011, 12:25 AM
  3. GSQ9669LW1 Whirlpool Washer Agitates, won't spin and makes noise
    By Jan123 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 27th, 2011, 01:11 PM
  4. Maytag A106 agitates & pumps but not spin
    By O-Don8r in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 15th, 2007, 09:05 PM
  5. Whirlpool direct drive agitates, pumps but doesn't spin
    By squareman in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 7th, 2006, 12:27 PM
