Results 1 to 7 of 7
Thread: Kenmore 80 series electric dryer: No buzz, No run, No heat, No spin, Door light works
    May 2012
    ontario
    Question Kenmore 80 series electric dryer: No buzz, No run, No heat, No spin, Door light works
    Model Number: 110
    Hello,
    We have a kenmore 80 series electric dryer. We replaced the belt about 3 months ago. When you press the start button, the buzzing sound does NOT occur. When you open the door, the light turns ON. When you manually hold the door part that activates the switch on and off, it turns the light OFF.
    All the threads I can find discuss broken belts and door switches, and the buzzing sound is present.
    As we have a working light and no buzz and a recently replaced belt, could anyone help us out? We always clean our lint traps, although I'm sure through the years we have a buildup. Is this enough to prevent the machine from starting or even the start button from buzzing?
    What should I do? It costs about $90 just to have a repairman out to my house.
    Thank you for your time,
    Joey
    Jul 2006
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    May 2012
    ontario
    The model number is 110.xxxxxx
    Also, you used to be able to hear the buzzer when the timer was in the off position and you pressed the start button, this is not occurring now. However when moving the timer, 'clicks' can still be heard.
    Jul 2006
    110.xxxxxxxx is not a model number. I need the eight digits that follow 110.
    May 2012
    ontario
    110.c62842102
    May 2012
    ontario
    sorry the actual number is 110.c62842101.
    Also, when you hold the start button down when the timer is set to any running setting, you can hear the timer clicking away, although there is no buzz and no running of the machine and no heat (as far as I can tell). And when the start button is held down in an off position, there is no buzz.
    Jul 2006
    You probably have an open thermal fuse but I'm unable to look it up. Some Canadian models we don't have information on in USA, and this is one of them. Jeff lives and has an appliance shop in Canada, he may know. You can go to Jeff's forum section here: Question and answer forum entrance for Appliance repair helps
  1. Kenmore Series 90 Electric Dryer No Heat ?!?
    By parttimerz in forum Sears Kenmore
    Last Post: December 30th, 2012, 02:14 AM
  2. FIXED: No Heat - again!? Kenmore 80 Series electric dryer
    By daggerNC in forum Sears Kenmore
    Last Post: July 31st, 2012, 10:42 AM
  3. FIXED: Kenmore 80 series electric dryer no heat
    By type2person in forum Sears Kenmore
    Last Post: January 30th, 2012, 07:23 PM
  4. Kenmore Series 70 electric dryer works sporadically?
    By TWOsFamily in forum Sears Kenmore
    Last Post: November 1st, 2011, 07:37 PM
  5. kenmore 80 series electric dryer-heat but will not dry
    By jtreiger in forum Sears Kenmore
    Last Post: July 23rd, 2005, 03:07 PM
