May 13th, 2012, 07:02 PM
#1
Kenmore 80 series electric dryer: No buzz, No run, No heat, No spin, Door light works
Brand:
Hello,
We have a kenmore 80 series electric dryer. We replaced the belt about 3 months ago. When you press the start button, the buzzing sound does NOT occur. When you open the door, the light turns ON. When you manually hold the door part that activates the switch on and off, it turns the light OFF.
All the threads I can find discuss broken belts and door switches, and the buzzing sound is present.
As we have a working light and no buzz and a recently replaced belt, could anyone help us out? We always clean our lint traps, although I'm sure through the years we have a buildup. Is this enough to prevent the machine from starting or even the start button from buzzing?
What should I do? It costs about $90 just to have a repairman out to my house.
Thank you for your time,
Joey
May 13th, 2012, 07:21 PM
May 13th, 2012, 07:39 PM
The model number is 110.xxxxxx
Also, you used to be able to hear the buzzer when the timer was in the off position and you pressed the start button, this is not occurring now. However when moving the timer, 'clicks' can still be heard.
May 13th, 2012, 08:09 PM
110.xxxxxxxx is not a model number. I need the eight digits that follow 110.
May 14th, 2012, 05:21 AM
#5
May 14th, 2012, 11:13 AM
#6
sorry the actual number is 110.c62842101.
Also, when you hold the start button down when the timer is set to any running setting, you can hear the timer clicking away, although there is no buzz and no running of the machine and no heat (as far as I can tell). And when the start button is held down in an off position, there is no buzz.
May 14th, 2012, 11:18 AM
#7
You probably have an open thermal fuse but I'm unable to look it up. Some Canadian models we don't have information on in USA, and this is one of them. Jeff lives and has an appliance shop in Canada, he may know. You can go to Jeff's forum section here: Question and answer forum entrance for Appliance repair helps
By parttimerz in forum Sears Kenmore
Last Post: December 30th, 2012, 02:14 AM
By daggerNC in forum Sears Kenmore
Last Post: July 31st, 2012, 10:42 AM
By type2person in forum Sears Kenmore
Last Post: January 30th, 2012, 07:23 PM
By TWOsFamily in forum Sears Kenmore
Last Post: November 1st, 2011, 07:37 PM
By jtreiger in forum Sears Kenmore
Last Post: July 23rd, 2005, 03:07 PM
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
