Results 1 to 9 of 9
Thread: VERY annoying dryer End of Cycle Signal
    Jun 2012
    nyc
    Question VERY annoying dryer End of Cycle Signal
    Model Number: LTE5243DQ
    Age: Less than 1 year
    Hello:
    I just purchased a model LTE5243DHQ Whirlpool 24" TwinThin - one of the main reasons we purchased it is we were informed by are dealers Whirlpool
    tech. adviser that we could turn of the dryers End of Cycle signal (or VERY annoying buzzer) by simply turning the Start Dryer button to the off position.
    Well we are very dismayed to find that is not the case - But, I have read several posts about just disconnecting one of the wires from the buzzer and carefully securing and safeguarding it so it does not short out - I have no problem doing this - BUT, my question is, will doing the void the warranty ??
    Thank you.
    Jul 2006
    No, it won't void your warranty as long as you tape the end of the wire so there is no chance it can short out. I tried to find a tech sheet but no luck so look at the two wires on it and see if you can trace the one that's connected to the neutral side and remove that wire. If you have your tech sheet and can post the wiring diagram here I'll tell you which wire it is.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jun 2012
    nyc
    Thank you so much for your reply - this is indeed good news - I do have the tech sheet which I removed from the plastic pocket on the machine, but I'm not sure how to
    post it.
    Jun 2012
    nyc
    Tech Sheet.pdf
    I hope I did this right. Tech Sheet.pdf If, I'm not mistaken, I think the wire I should disconnect is the BK wire that goes from the Buzzer to what I think is a gound point.
    Jun 2012
    nyc
    Opps! sorry I think I did the attachment twice.
    Jul 2006
    Leave the black wire on. That's the hot side. Remove the blue wire that's the neutral side.
    Jun 2012
    nyc
    Quote Originally Posted by rickgburton View Post
    Ok, thanks. Just the opposite of what I thought. Just to verify on accessing the buzzer - I remove the 4 phillips screws (2 per side) remove the plastic end caps
    and pull out and down on the front panel - is this right? Putting it back - a bit trickier, but reverse the process?
    Jul 2006
    That sounds right to me.
    Jun 2012
    nyc
    I've opened the front control panel - and suprise, both wires going to the buzzer are black, one of the BK wires has writing on it the other is just black.
    I decided to just disconnect both wires and wrapped them well in electrical tape - now, I'm trying to figure out the control panel goes back in place - not as
    simple as I thought it would be!
  1. Auto stop and signal when unbalanced spin
    By dbbyleo in forum Washers
    Last Post: August 31st, 2010, 12:09 PM
  2. [FIXED] Ice Maker Wire Signal Arm problem
    By DonW in forum Sears Kenmore
    Last Post: July 10th, 2007, 01:30 PM
  3. unbalance signal stays on
    By hayman_69 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 10th, 2007, 11:46 AM
  4. Cycle Completion Signal shu8806 uc/12
    By gooneybird in forum Bosch
    Last Post: September 11th, 2006, 09:41 AM
  5. end of cycle signal - Maytag Performa dryer
    By boaretired in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 5th, 2006, 12:31 AM
