Results 1 to 4 of 4
Thread: Whirlpool (RBS305) Error Code - F3 E2
    Sep 2012
    Dallas
    Default Whirlpool (RBS305) Error Code - F3 E2
    Model Number: RBS305PDQ14
    Hello,
    I've recently started receiving an error on my display panel - F3 E2. The oven doesn't seem to be heating up properly and when the error appears, the oven is locked.
    I've also noticed that the oven, after being used and turned off, will make a "crackling" noise.
    Any thoughts or input would be greatly appreciated.
    Jeff
    Last edited by wardrjeff; September 5th, 2012 at 09:26 AM. Reason: WRONG MODEL CODE
    Jul 2006
    Ohm check your oven sensor with a multimeter. It should read 1080 ohms at room temperature.
    Oven Sensor W10131825 Order now for same day shipping. 365 day return policy. RepairClinic.com
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Sep 2012
    Dallas
    Hi Rick,
    i replaced the oven sensor but I'm still receiving the E2-F3 error. Is there a "hard-reset" that I can initiate or should I contact a professional?
    thanks,
    Jeff
    Jul 2006
    The F is the fault code and the E is the error code. F3-E2 is, the oven temperature is going above 575*F in Bake mode. Once it reaches that temperature, it thinks it's in Self Clean so it locks the door. If the oven sensor is good then the relay contacts on the board are probably welded together. When you turn on the bake function, do both elements in the oven turn on? I can tell you how to check voltage but I'm guessing since you replaced the sensor and it didn't solve the problem, you don't have a meter to measure anything. Here's the electronic control for your model:
    Oven Control Board WP8302994 Order now for same day shipping. 365 day return policy. RepairClinic.com
  1. whirlpool oven error code fixed problem still have error code
    By whodey79 in forum Whirlpool/Roper/Estate
    Last Post: November 1st, 2010, 01:25 AM
  2. Whirlpool GBD307PDQ09 has error code PF E06
    By jbd547 in forum Whirlpool/Roper/Estate
    Last Post: October 31st, 2009, 02:20 PM
  3. Whirlpool -F2- Error Code -HELP!
    By rvweb in forum Whirlpool/KitchenAid
    Last Post: August 7th, 2008, 06:17 PM
  4. Whirlpool RBS305 won't heat...
    By akevitt in forum Whirlpool/Roper/Estate
    Last Post: October 11th, 2007, 01:55 AM
  5. Whirlpool E7 F1 Error Code
    By blsnelling in forum Whirlpool/Roper/Estate
    Last Post: December 31st, 2006, 10:40 PM
