Results 1 to 2 of 2
Thread: Frigidaire Affinity E5E
    Sep 2012
    Default Frigidaire Affinity E5E
    Model Number: LAFW3511KB0
    Brand: Frigidaire
    When I turn the washer on and start a cycle, it will add water for a few seconds then shut off. It does this a few times and then it does nothing else. Its like it freezes. I turned it to the spin cycle and the pump comes on and drains water out, but the tub does not spin. I ran the diagnostics and it came up with E5E. I have been looking around the forum and I was wondering what I need to do from here. Any help please!!
    E5E Communication problem. Refer to test (11).
    Test 11: 1. Communication problem. Check the wiring between the control board and the speed control board.
    Solution: Wiring bad: Correct wiring problem.
    Wiring good: Replace the control board.
    If the problem is not corrected, replace the speed control board.
    Here's the control board for your model you can order here:
    Main Control Board 137006060 Order now for same day shipping. 365 day return policy.
    Here's the speed control board for your model you can order here:
    Motor Control Board 134743500 Order now for same day shipping. 365 day return policy.
    If you purchase parts from our links here and you install them and it doesn't fix the problem, you have a 365 day full refund when you return them.
  1. Frigidaire Affinity E57 code
    By ktbloom in forum Frigidaire/Electrolux
    Last Post: September 14th, 2012, 07:24 PM
  2. Frigidaire Affinity stops upon arriving at the spin cycle E43
    By Just2sweet143 in forum Frigidaire/Electrolux
    Last Post: August 25th, 2012, 08:30 AM
  3. Frigidaire Affinity FAFW3801LW, should I buy it?
    By Sears in forum General Appliance Chat
    Last Post: October 24th, 2011, 07:34 PM
  4. Frigidaire Affinity Dryer
    By jafish in forum Frigidaire/Electrolux
    Last Post: May 9th, 2011, 05:20 PM
  5. Frigidaire Affinity
    By speedway in forum Frigidaire/Electrolux Reviews
    Last Post: February 12th, 2009, 01:04 PM
