Results 1 to 6 of 6
Thread: Water leaking from bottom of refrigerator after replacing water filter
    Sep 2012
    delaware
    Default Water leaking from bottom of refrigerator after replacing water filter
    Model Number: GX5FHTXVY05
    After replacing the water filter I noticed water leaking from the bottom of refrigerator ... no leaks at filter or dispenser. I flushed air out of system.
    Ok, can you pinpoint exactly where the leak is coming from? Get a flashlight and look under the refrigerator and behind it, Pull the refrigerator out from the wall and remove the lower access panel and check in there too.
    Sep 2012
    delaware
    Thanks for your quick response. The puddles are at each corner of the bottom of the refrigerator at the front ... sometimes only on one side. I will try what you have suggested.
    Glenn
    Ok Glenn, yes try to pinpoint where its coming from.
    Sep 2012
    delaware
    There was a sheet of ice at the bottom of the freezer ... after removing that ... no more leaks ... I didn't see it until I removed all of the food ... in addition, someone had removed the filter without me knowing ... chances are the water settled down in the freezer at that time. Anyway, no more leaks ...
    Glenn
    Ok Glenn, sounds good.
  1. Refrigerator Water Filter Leaking
    By chbrandt in forum Frigidaire/Electrolux
    Last Post: May 30th, 2012, 01:25 PM
  2. Leaking water on the bottom of the refrigerator
    By edwards1687 in forum Whirlpool/Roper/Estate
    Last Post: January 17th, 2012, 09:47 PM
  3. Admiral refrigerator HMG641847 leaking water/ice build up in bottom tray
    By Erstram in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 4th, 2011, 01:39 AM
  4. Replies: 0
    Last Post: August 30th, 2011, 05:43 PM
  5. Replacing a water filter
    By pucara in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 14th, 2010, 04:03 PM
