Results 1 to 2 of 2
Thread: 417.44052401 Kenmore Washer does not spin with initial error code E59
    Mar 2006
    Modesto, CA
    Default 417.44052401 Kenmore Washer does not spin with initial error code E59
    Model Number: 417.44052401
    Kenmore Front Load Washer does not spin with initial error code E59 and then E52 during the diagnosis.
    All of sudden our washer stopped after rinse cycle and about to spin.
    Initial error code received: E59 (5 times flashing five indicator lights and 9 times START indicator lights along with five indicator lights).
    After reviewing different topic in this board, I have checked speed control board for any loose cable connection, Made sure all the cables connected and did the diagnostic test. I could do the steps up to step 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. On this step 7, it tried to spin, got stuck and displayed error E59. I unplugged and power cord, inspected again for loose connection. None found.
    Test 12 for E59 was done. Tested resistance with multi-meter, showed 115 ohms between 4 & 5 pins. 6.2 ohms betwee 1,2,3 pins.
    I tried to spin the tub manually couple of times, I felt little hard, thought some clothing got between the drum/tub.
    Tested again with diagnostic test, it got stuck again on step 7, I tried to go to step 8 with flashing error code and moved back to step 4/5 and again step 7, 8, 9 and 10. I received new error E52 (5 times flashing five indicator lights and 2 times START indicator lights along with five indicator lights).
    I checked
    Test 10 for E52, It shows that I replace speed control board.
    Before I want to order speed control board. I want to get expert opinion and help.
    Model: 417.44052401 We have owned this Kenmore washer last 6 years, purchased in 2006 from Sears.
    Thanks in advance. Ron
    Jul 2006
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
  1. GE washer wont spin - ul error code also
    By Joe Joe in forum GE/Hotpoint
    Last Post: October 29th, 2015, 11:22 PM
  2. Kenmore "3E" error code - washer will not spin
    By goldmember in forum Sears Kenmore
    Last Post: January 13th, 2015, 11:56 PM
  3. Replies: 5
    Last Post: November 23rd, 2013, 10:34 AM
  4. Kenmore 417.44052401 Washer not spinning
    By KE.Lesh in forum Sears Kenmore
    Last Post: May 20th, 2012, 12:47 PM
  5. Kenmore Front Load Washer 417.44052401 no spin
    By bcarew in forum Sears Kenmore
    Last Post: November 29th, 2007, 03:24 AM
Tags for this Thread
