362.75295790 Conversion from LP back to Natural gas
MAXIES123
MI
Hi
I have this range that was converted from natural gas to lp, i want it to be converted back to natural gas, i have no instructions on how to do this as the instructions were with the orifices that I do not have, I am looking for these instructions . The range was natural gas and was converted to lp, i want it to be converted back to naturalgas.
A copy:
Converting to LP gas (or converting back to natural gas from LP)
This range leaves the factory set for use with natural gas, If you want to convert to LP gas, the conversion must be performed by a qualified LP gas installer. The conversion instructions, sticker and LP orifices can be found attached to the
range next to the pressure regulator. There is a second set of instructions included in the envelope containing the product
wiring diagrams on the back of the range.
Keep these instructions and the orifices in case you want to convert back to NG.
Parts breakdown doesn't say which is what and how many is required.
Orifice spud, NG 1.75MM
Gas burner orifice, natural gas, 1.52 mm
Gas burner orifice, natural gas, 1.07 mm
If your instructions are not there, don't know where you can get them as the LP conversion kit is NLA.
