FIXED 363.58042891 Kenmore Side By Side intermittently makes short buzzing sound
strfkr
Bronx, NY
Hello,
I have a Kenmore side by side fridge that works fine but it has been making an intermittent buzzing sound lately.
It started out making the noise every once in a while but has become more frequent over the last few weeks. It now occurs about every 30 or 45 minutes and lasts for about 7-10 seconds.
There are no signs that anything else is wrong. Freezer and fridge are both cold. The motor and/or compressor do not sound any different.
Any ideas?
strfkr
Bronx, NY
ps
It has an ice maker but it is not hooked up to a water source.
Not sure how old the fridge is but it is probably close to 10 years old.
bigbuck
From Planet Mars
Refrigeration Noise - Buzzing
Buzzing Noises
If the refrigerator has an ice maker but is not connected to a water supply, the water valve will make a buzzing or clicking sound as it tries to fill the ice maker.
Check that the ice maker is turned off if the refrigerator is not connected to a water supply.
To turn the Ice Maker Off
The On/Off switch for the ice maker is a wire shutoff arm located on the side of the ice maker.
strfkr
Bronx, NY
That was it.
I had a feeling it had to do with the ice maker. Seems that the arm was jammed under the ice maker.
I think I am just going to remove the ice maker since the fridge is no where near a water source.
Thanks a lot for the help.
