363.63674201 Kenmore Elite Microwave Oven Handles? OEM? same size parts?
vote4pedro
VA
My Kenmore Elite microwave 363.63674201's door handle just broke again after my last attempt to JW Weld failed. Looking around I can't find the door handle manufactured or available anymore. Was wondering if I can use a generic door handle? At this point i don't care about looks. I just want a door handle. whats the best way to find something compatible?
Measure from the center of the screw holes and check the home centers
vote4pedro
VA
here's the top handle layout
vote4pedro
VA
it broke on the other end. the screw hole is shattered. I tried to JB Weld it but that's busted too now
Drill a hole straight through the screw hole and out the front of the handle. Use a longer machine screw with a lock washer and nut
vote4pedro
VA
i guess there's no generic handle i can use? that's not the prettiest look but i guess that can work
vote4pedro
VA
thanks for that info. for the machine screw suggestion, is there a type of metal i should be looking for to use? always been told not to put metal in microwave
vote4pedro
VA
also since i'm thinking about this further. can I slap another GE door on this? if so what type of doors should i look for?
vote4pedro
VA
there is a metal screw that holds the handle (from the inside) currently. it's on the door but still inside the microwave. since i will likely need a longer one, wasn't sure if there's a type of material that thing is made out of currently
vote4pedro
VA
just an update. I've decided to just JB Weld the whole bottom bracket and see how long that lasts. I'll rough up the inside a bit for jb weld to grip on to
