Results 1 to 4 of 4
Thread: F3 E2 Error on Whirlpool oven
    May 2013
    Chicago
    Default F3 E2 Error on Whirlpool oven
    Model Number: RBS305PDQ16
    I preheat the oven and after about 10 minutes I received an error code F3 E2. I then checked the resistance of my temperature sensor. It was 1101 ohms at room temperature, ~75 degrees. I read it should be about 1080 ohms. Is the reason for the error? Is the resistance tolerance that tight? I have a Whirlpool RBS305PDQ16 oven.
    Oct 2004
    F3 E2 Oven temp too high - over 575F (301C) in COOK mode
    1.Check sensor connection.
    2.Measure sensor resistance (1080Ω at 70F [21C]. Add 2Ω per degree F).
    3.If resistance is not valid, replace sensor.
    4.If sensor resistance and connections are good, then check for
    welded-closed relays on the control.
ID:	10510 Oven sensor Manufacturer Number W10131825
    Check the wiring to and from the sensor also!
Size:  3.3 KB Electronic control board Manufacturer Number 8302994
    http://www.applianceaid.com/
    Appliance Repair Aid
    Yeah I've got O.C.D.....Old, Cranky and Dangerous.
    Tip of the day, set your Samsung Smart Fridge to a foreign language so Google can't spy on you!!
    May 2013
    Chicago
    So how tight is the tolerance on the sensor? At ~75 degrees it should be 1090 ohms while my sensor recorded 1101 ohms. Is this enough to warrant replacement of the sensor? Or should I try replacing the control board?
    Oct 2004
    I would say that is close enough....but sensors can also go funky once heated....given the 2 choices I'd go with the least expensive part first.
    JMO.
  1. FIXED: RBS245PDB11 Whirlpool oven error code F3 E2
    By mlamont in forum Whirlpool/Roper/Estate
    Last Post: November 16th, 2017, 12:20 AM
  2. whirlpool oven error code fixed problem still have error code
    By whodey79 in forum Whirlpool/Roper/Estate
    Last Post: November 1st, 2010, 01:25 AM
  3. Whirlpool Freestanding Range/Oven - PF Error
    By jbruns in forum Whirlpool/Roper/Estate
    Last Post: February 5th, 2008, 05:05 AM
  4. Whirlpool Oven F3 Error Code
    By salacy in forum Whirlpool/Roper/Estate
    Last Post: September 7th, 2007, 06:27 PM
  5. Whirlpool Built-in Oven Error E3 F2
    By ChuckA in forum Whirlpool/Roper/Estate
    Last Post: March 6th, 2006, 02:51 AM
