401.80082700 Microwave Not Latching
RSGlover
Minnesota
Microwave door won't stay closed/latched
Wondering whats the best way to determine what part has most likely failed. Microwave Latch Body and Switch Assembly or Microwave door interlock switch lever?
Thats a good question, I'll see if Rick knows what part you need.
Here's the part you need:
DE64-00760A Door Latch Hook
What most likely happened is the small tab on the latch that holds the spring broke off. If you're handy, drill a very small hole in the latch where the tab broke and hook the spring there.
