417.44152400 Bank of lights won't stop blinking
Wadsworth
There is a bank of lights on the right side of the panel that keeps blinking when the machine is plugged into the wall. It happened once, and after unplugging it for a few minutes it reset. That solution is not working a second time. Pushing the other buttons will not stop these lights, and with those blinking, nothing else will accept entry. Any suggestions would be appreciated.
The control signals a failure code by flashing the five indicator lights. The five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit. Take separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
