417.48102701 Kenmore Washer Beeping
Joylynn
Mississippi
My kenmore 41802 front load washer is beeping. I changed the control board and now the lights over the cancel button all light up and flash. They flash 10 times with beeping. When the machine first stopped I cleaned out the drain filter. Any suggestions. The machine will not do anything but beep.
Added model number
41802 is not a model number, read it from the tag on the machine.
Click here: Appliance Parts
Nope, where did you buy it from? Its definity bad.
What was it doing before you replaced it?
Let's check for a error code.
Read Page 10 in the service manual I posted above. You have the "GOOD" model(non-digital display). So an error code will be read with the flashing lights you count.
If you can't even get it to run the diagnostics, then it's definitely a bad main control board.
