Flash3102
- 417.48112701
- Sears Kenmore
- More than 10 years
I have a kenmore front load model 417 that started making this loud noise when it was on fast spin and was also not draining all the water out. I clean the drain and filter and still did the same thing. So it sounds like I need to replace the bearings on the drum and appliancespartspros.com said that you have to buy the drum completely, that you cant buy the bearing separately.
The new drum with bearings is $377 but I found the inner and outer bearings with the seal that are made for that model (I thought) for about $75. So is it true you have to buy the entire drum or can I just find the bearings and seal, just somewhere else?
