refrigman
- 417.48112701
- Sears Kenmore
- More than 10 years
My Frigidaire manufactured front load "good" model washer 417.48112701 has same symptoms. Final spin doesn't happen with "no-spin" light coming on in place of chosen spin speed. Also door lock light stays on until cancelled manually. Going through diagnostics the 8th click setting does drain and door lock but no spin. Code comes up as E43 which is listed as "board communications problem" with replacing the control board as the solution. The only control board I find listed is the motor control board 134743500 but is that the board in question? Isn't there a control board in the control panel that controls functions such as drain, fill, door lock, etc and gets input from door switch, for instance, other than motor functions. If so, which "control board" is code E43 saying needs to be replaced?
