- 417.61712510
- Sears Kenmore
- 1-5 years
Working on a Kenmore 61712 stacked washer and dryer combo. Purchased it used very cheap almost a year ago for a rental, never had issues, until now. The dryer starts to run for about 2-3 seconds and then shuts off.
This unit is installed outside in a carport, it has a roof covering it from rain and one wall, but open to temperature and lately it’s been getting down below 30*F at night and 40-50*F during the day. The washer was not being used below 35*F and water lines were getting disconnected to prevent freezing. Washer still works fine. But the dryer started to have issues. I was thinking could be condensation building up inside from dryer getting hot in a cold environment, could be the moisture in the air, when I took the mid-panel off (below the main board), it was totally dripping with condensation, even the manual inside was all soaked through.
I ran diagnostics and got error codes E51, E71, and EA3 (below). Exhaust vent isn’t clogged, appears to have a good suction, reset the breakers just to be sure, measured voltage as 122v on one leg, 124v on another leg, with 246v total output at the wall outlet. Thermistor (NTC) was close to range (should be 50k ohm), it was 40*F outside, so it initially showed around 90k ohm, then I brought it inside, the resistance gradually went down to 18k ohms as the bugger sat warming up in front of a heater.
Possible Fault Conditions per manual:
E51 – Motor relay stuck open; Locked Rotor; Harness; Connectors; Low Power Supply; Thermal Limiter 1 open; Motor Centrifugal Switch stuck open or close
E71 – NTC open circuit; Wiring; Main Board
EA3 – Main V < 180vrms; Microprocessor Corrupted; Main Board
Questions:
- Based on the combination of 3 errors above, is it looking like the main board is likely fried, or could it be something else?
- Is “control” board and “main” board the same thing in this machine?
- How can I check Motor Centrifugal Switch and where is it?
- How can I check Thermal Limiter 1? (will need specs)
- Can I test the main board somehow before replacing it? (will need specs and points)
- Can I test wiring harness? (will need specs)
- How likely is the dryer to have problems due to corroded terminals? I did not observe any visibly bad corrosion, but sometimes it’s hard to see, should I just clean all connectors? Same idea as cleaning car battery posts.
Questions:
