417.61712510 Kenmore Washer/dryer combo, Washer not doing high speed spin
Ejreilly
New york
Looking for some help, i have a kenmore washer/dryer combo that is having a problem with the washer. The issue is that the machine will not go into hi-speed spin. I have done already a number of things to try and fix the problem, first I was told to replace the motor control board (located underneath machine). Replaced it with new part from sears and did not fix the problem. Then, i was told to replace the main computer board (located behind the washer control knob on dashboard) , that too did not fix the issue. Lastly, when you put the machine in diagnostic mode and manually cycle through, the machine goes into hi speed spin, but not during normal use. If anyone could help, it would be greatly appreciated, this is driving me nuts.
