Results 1 to 5 of 5
Thread: Maytag MDE7600 has short dry time
    Jun 2006
    Oregon
    Default Maytag MDE7600 has short dry time
    My Maytag MDE7600 will not dry through a full cycle. I turn it on and the moisture monitor only displays to "less". We have to reset twice to get a load done. It seems to heat fine, it just wont complete a cycle. It doesn't matter if its on auto dry or timed dry either. Any ideas?
    If your timer is not moving even on timed dry, then you have a faulty timer.
    Here is the timer for your model:
    Timer
    Jun 2006
    Oregon
    The timer moves, it just moves very quickly as if the moisture sensor doesn't work right. Is that possible?
    Then I would check to make sure you don't have a vent restriction where your dryer vents to outside first.
    Pull your dryer away from the wall, then run a load with no vent hooked-up at all, to see if the problem goes away.
    May 2011
    Iowa
    Default Check for a proper ground
    Check for a proper ground. In my case I had a four wire plug fed by a 3 wire cable. Hence, no ground.
    No Ground = No IntelliDry
    InfoGates: Maytag Atlantis IntelliDry not working - Blog
  1. FIXED: maytag neptune mdg5500aww sensor dry not drying
    By bdlathome in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 7th, 2012, 10:04 PM
  2. Maytag MDE9206AYW drying time too long
    By MPD in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 19th, 2007, 12:01 PM
  3. Maytag MDG3706AWW auto dry/auto dry wrinkle won't stop
    By pherbolario in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 6th, 2007, 06:45 PM
  4. GE Profile with moisture and increased dry time
    By popolary in forum GE/Hotpoint
    Last Post: October 24th, 2006, 09:58 PM
  5. Older Maytag timer knob doesn't pop in every time
    By zman in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 2nd, 2006, 02:58 PM
