Results 1 to 4 of 4
Thread: Whirlpool Gold - Runs until timer hits 39min - then start button blinks 4 times - Can be restarted
    Apr 2014
    Central Ct
    Default Whirlpool Gold - Runs until timer hits 39min - then start button blinks 4 times - Can be restarted
    Model Number: GU2700XTSS1
    Greetings!
    I have a Whirlpool gold that is about 5 years old and is showing the following symptoms.
    A normal wash cycle runs until the timer shows 39 minutes. The cycle will halt. Then the Start button will flash 4x
    If you press start it can resume and finish to completion. ( I may need to restart a few more times to finish the cycle)
    I browsed this forum and performed the system reset function.. It cycled through that without any codes.
    I did pop off the spinner and pump filter and checked the chopper and screen. All look good there.
    I checked the water temp mid cycle and it was good and hot.. ( i'd figgure 110-120 deg f)
    I need to figgure out what else i can do for troubleshooting this DW.
    Thanks in advance!!!
    Yes, the problem is the control panel keypad assembly itself, the start button shorting out causing the stoppage and blinking light.
    Here's the control panel keypad assembly for your model you can order here:
    Whirlpool W10021010 Panel-Cntl - AppliancePartsPros.com
    Apr 2014
    Central Ct
    Thank you Jake... I will order this part cuz the wifey made this a priority Ha Ha!!!
    Ok Larry, sounds good, keep us posted.
  1. FIXED: GU2475XTVY1 Whirlpool Gold Quiet Partner IV Cancel/Drain Light Blinks
    By jaytay9 in forum Whirlpool/Roper/Estate
    Last Post: March 2nd, 2014, 09:06 AM
  2. Replies: 3
    Last Post: September 24th, 2013, 07:51 PM
  3. Replies: 5
    Last Post: May 23rd, 2013, 11:57 PM
  4. Gas dryer only runs while holding start button
    By kenlaz in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: June 8th, 2012, 01:02 PM
  5. Replies: 1
    Last Post: January 6th, 2012, 05:44 PM
