Results 1 to 5 of 5
Thread: Repair manual - need to unplug water pump
    Nov 2006
    maine
    Default Repair manual - need to unplug water pump
    Model Number: MVWC200BW0
    Brand: Maytag
    Age: Less than 1 year
    May need to unplug water pump, so would like to know how. Thanks
    Jul 2006
    Unplug the machine and disconnect the water hoses. Lay the machine down on it's front. Remove the hose clamp and hose from the pump. Remove the three pump mounting screws. Remove the pump. Note the drain pump seals at two different spots on the tub so make sure both surfaces are clean when you reassemble it.
Name:	MVW WTW Pump 1.jpeg
ID:	16326Click image for larger version.
Name:	MVW WTW Pump 2.jpeg
    Drain Pump W10276397 Order now for same day shipping. 365 day return policy. RepairClinic.com
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Nov 2006
    maine
    Thanks. Just retired my Magtag A501 after 33 years, tub rusted through. Been in cellar all that time. In an earlier post there was MVWC300 repair manual, looks close for major parts, different panel controls.
    Jul 2006
    If I had an A501 I wouldn't get rid of it. I would periodically check with used appliance dealers/stores and let them know you're looking for a used tub. Those are good machines. Depending how bad the rust is, I've repaired many rust holes on those style tubs before. The worst spot is where the center seal is.
    Nov 2006
    maine
    It's gone, never to be seen again. I did any work it needed, 1 water pump, some belts. It's was also about 100 lbs heavier than the new unit. New unit has 5 yr warranty for $99, hard to beat that. By the repair manual, 200 is easy to work on, I guess it has to be.
  1. Duet Sport F21 code - Pump seems to work fine(Repair Manual link)
    By Mara Vernon in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 24th, 2015, 08:44 AM
  2. Replies: 0
    Last Post: December 17th, 2013, 11:48 PM
  3. Repair Manual
    By jimvh2 in forum KitchenAid
    Last Post: February 19th, 2012, 10:57 PM
  4. Tech manual/schematic/repair manual
    By Tuffluck in forum Whirlpool/KitchenAid
    Last Post: September 19th, 2011, 09:47 PM
  5. how do you open the washer to repair the water pump?
    By arcangel in forum Sears Kenmore
    Last Post: January 15th, 2007, 03:28 PM
