Results 1 to 10 of 10
Thread: JP939SH1SS GE Profile 30 inch Glasstop Cooktop - Error Code F153
    Apr 2013
    Bristol, CT
    Default JP939SH1SS GE Profile 30 inch Glasstop Cooktop - Error Code F153
    Model Number: JP939SH1SS
    Brand: GE
    Hello,
    I have a GE Profile 30" Glasstop Cooktop (Model #JP939SH1SS) with the error code "F153" showing up on the cooktop surface. This error code only appears when utilizing the front right large burner. I reviewed the trouble shooting section in the owners manual and after applying the suggested corrective measures, the F153 error code reappears. Any insight on this situation? What parts may be required to repair this? I am extremely mechanically inclined, so is this a DIY repair? Do I need to call an actual service repair facility/individual? Any help would be appreciated. I look forward to the responses......
    Jul 2006
    "F153" indicates an open temperature sensor for the right front burner. Check the heater, sensor and wire harness connections and make sure they are tight and secure. Check the heater ribbon for any damage. Disconnect the sensor connector from the board and measure the resistance of the sensor. It should be between 1030 and 1150 ohms. If not replace the heater and re-calibrate the inductive sensors. If the problem persists, replace the power board.
    Solid Surface Element WB30T10062 Order now for same day shipping. 365 day return policy. RepairClinic.com
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Apr 2013
    Bristol, CT
    Hello Rick,
    thanks for the response and the insight. I have the ability to check the ohms as stated. If I check the ohms and they are in within the values stated, will it just be the Solid Surface Element needing replacement? Will I need to replace the heater as well? Can you show the heater part as well? How is the recalibration handled on the inductive sensors?
    Jul 2006
    Sorry, the heater/element and RTD sensor are all one unit (In the picture above). Do not cut or splice any of the wires for the RTD and inductive wire. They are wired to the connector at the factory. So basically, if all the wires are tight and secure and show no visible signs of damage, you'll need to replace either the RF Element or the power board. Element if the RTD sensor is open or Power board that's telling you the sensor is open if it's not. The instructions for calibrating the inductive sensors is on your tech sheet. Look for an envelope taped to the bottom of the cook top. The parts will come with calibration instructions also. If you don't need a part you won't need to recalibrate.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Apr 2013
    Bristol, CT
    Hey Rick,
    So I am understanding this properly.... The Solid Surface Element (WB30T10062) and the heater/element & RTD sensor are the same unit? How do you determine if the RTD sensor is open or if the Power Board is telling you the sensor is open? Do you have a picture/price/part number for the power board? Is this available thru the same place as the Solid Surface Element? Also, do you have a exploded view of the cooktop parts and parts number list? How about a wiring diagram? Or is that with the envelop under the cooktop? I greatly appreciate this. Don't want to call a repair man unless I need to.
    Jul 2006
    Quote Originally Posted by John King View Post
    How do you determine if the RTD sensor is open.
    Quote Originally Posted by rickgburton
    In post#2 the connector is the white plastic piece at the end of the wires. Ninety percent of the time replacing the unit/element will fix the problem.
    That's correct.
    Here's the parts diagram: Parts for GE JP939SH1SS: Cooktop Parts
    Feb 2018
    Rosharon Tx
    I also have the same error code on my display. I followed your directions but my meter isnít registering any ohms. Does that sound like I should replace element or the board Rick? Also, if it is indeed the element & itís wired from the factory, does that mean that all of the other connectors come with the element too? In the above pic, I see just the 2 blue wires & the RTD. My element has 3 more wires on it.
    Model JP938B0C1BB
    I thank you in advance.
    The envelop was missing on the bottom of my cooktop but I found some instructions inside after opening.
    Jul 2006
    Your range uses the same element as in post #2. It comes with instructions.
    Radiant Surface Element WB30T10062
    Feb 2018
    Rosharon Tx
    Thanks Rick. Guess Iíll buy the element then. I hope the element fixes my problem & itís not the board.
    Jul 2006
    The error codes are pretty much straight forward. F153 is an open sensor for the right front element. You checked it with a meter and it was indeed open. It's rare to have more than one part fail at a time.
  1. Samsung FE-N300WX cooktop problem TE error code
    By mforgues in forum Ranges/Ovens
    Last Post: June 23rd, 2015, 10:27 AM
  2. Code F153
    By rcpilotkaos in forum GE/Hotpoint
    Last Post: October 15th, 2013, 04:57 PM
  3. GE Cooktop Fault code f153
    By jf060 in forum GE/Hotpoint
    Last Post: October 15th, 2013, 04:55 PM
  4. Replies: 1
    Last Post: January 9th, 2013, 12:46 PM
  5. GE Profile Error Code F0
    By rooster6776 in forum GE/Hotpoint
    Last Post: December 20th, 2012, 11:36 PM
